Zum Hauptinhalt wechseln
Lenovo ThinkPad X220 Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad X220 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 2 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 3 von 3
    • Push the switch numbered 1 to the left to unlock it.
    • This switch will stay in this position.
    • Push the switch numbered 2 to the right and hold it in to unlock it.
    • This switch needs to be held in as you start to remove the battery as this switch is designed to stay in the locked position.
    • Remove the battery by sliding it upwards.
  2. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Remove the seven 5 mm Phillips #00 head screws for the keyboard and trackpad.
  3. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Flip the laptop over and open the lid.
    • Gently push the keyboard towards the screen and use your opening pick to help lift up the keyboard.
    • Gently pull on the connector tab to disconnect the keyboard.
  4. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 4, Bild 3 von 3
    • Flip up the black ZIF locking flap.
    • Pull on the blue tab to disconnect the ribbon cable.
    • Lift up the trackpad and set it aside.
    • The trackpad may stick to one side. If you are having trouble removing it you can use your opening pick to help pry the trackpad loose.
  5. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Gently lift both coaxial connector cables to disconnect them from the Wi-Fi card.
    • If needed, you can use a pair of tweezers.
  6. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the 4 mm screw securing the Wi-Fi card.
    • As you remove the screw, the Wi-Fi card will lift up on its own.
    • Pull the Wi-Fi card from its socket at the same angle it lifts to.
  7. Lenovo ThinkPad X220 Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Insert the new Wi-Fi card and reinstall the 4 mm Phillips #00 screw that secures it.
Abschluss
Scrub_Jay
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 74
Insgesamt: 281
