Zum Hauptinhalt wechseln
Lenovo ThinkPad X260 Cooling Fan Replacement
Was du brauchst
  1. Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: Schritt 1, Bild 1 von 2 Lenovo ThinkPad X260 Cooling Fan Replacement, External Battery: Schritt 1, Bild 2 von 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 2, Bild 3 von 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: Schritt 3, Bild 1 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: Schritt 3, Bild 2 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 4, Bild 3 von 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X260 Cooling Fan Replacement, Cooling Fan: Schritt 5, Bild 2 von 2
    • Remove the four 2.9 mm screws that hold the cooling fan in order of 4, 3, 2, 1 using a Phillips #1 screwdriver.
    • Gently lift the plastic retaining flap to disconnect the ribbon cable.
    • The plastic that holds the ribbon wire in place is a black lever on a tan block.
  6. Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 6, Bild 2 von 2
    • Gently remove the wires which run along the fan.
    • Remove the old cooling fan.
  7. Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 7, Bild 2 von 2
    • Clean the old thermal paste off of the CPU.
    • The CPU, when clean, should have a glossy black finish.
  8. Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad X260 Cooling Fan Replacement: Schritt 8, Bild 3 von 3
    • Apply new thermal paste to the CPU.
    • Place the new fan in position and secure by reatching the screws in the order of 1, 2, 3, 4.
Abschluss
Alexander Webb
193 Reputation
2 Anleitungen geschrieben
IUPUI, Team 1-3, Harley Summer 2023 Mitglied von IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 45
Insgesamt: 523
