Zum Hauptinhalt wechseln
Lenovo ThinkPad X260 Internal Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: Schritt 1, Bild 1 von 2 Lenovo ThinkPad X260 Internal Battery Replacement, External Battery: Schritt 1, Bild 2 von 2
    • Make sure that the device is unplugged and turned off.
    • Flip the laptop from the front to the back.
  2. Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 2, Bild 3 von 3
    • Start by pinching the switches on either side of the battery outwards.
    • At the same time push the external battery, located in the back, upwards.
    • Remove the external battery from the laptop.
  3. Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: Schritt 3, Bild 1 von 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: Schritt 3, Bild 2 von 3 Lenovo ThinkPad X260 Internal Battery Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Loosen the eight 4.2 mm screws holding the back cover on using a Phillips #1 screwdriver.
    • These screws should be held in place by a small plastic washer which secures them to the cover and should not be loosened. This is illustrated in the third image.
  4. Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 4, Bild 3 von 3
    • Gently pull the cover off and set aside.
    • An iFixit opening tool may make it easier to gently remove the cover.
  5. Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X260 Internal Battery Replacement, Internal Battery: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Detach the black battery connector using a pair of tweezers.
  6. Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.3 mm screws locking down the battery using a Phillips #1 screwdriver.
  7. Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 7, Bild 1 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 7, Bild 2 von 3 Lenovo ThinkPad X260 Internal Battery Replacement: Schritt 7, Bild 3 von 3
    • Carefully remove the internal battery unit from the laptop using an iFixit opening tool.
    • Pick up the battery and take it off the laptop frame.
Abschluss
Ammarin Sinthana
97 Reputation
1 Anleitung geschrieben
IUPUI, Team 1-3, Harley Summer 2023 Mitglied von IUPUI, Team 1-3, Harley Summer 2023
IUPUI-HARLEY-SU23S1G3
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 36
Letzte 30 Tage: 138
Insgesamt: 1,439
