Zum Hauptinhalt wechseln
Lenovo ThinkPad X280 Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad X280 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X280 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X280 Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Battery Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo ThinkPad X280 Battery Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo ThinkPad X280 Battery Replacement, Battery: Schritt 4, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Haley Curry
434 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 1-3, Bedsole Fall 2021 Mitglied von University of Alabama, Team 1-3, Bedsole Fall 2021
UA-BEDSOLE-F21S1G3
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
but what about the batteries connection to the mobo?
edit: nvm, i assumed it was a cable not just a connector
Matthew Gould - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 60
Letzte 30 Tage: 254
Insgesamt: 7,040
