Zum Hauptinhalt wechseln
Lenovo ThinkPad X280 Fan Assembly Replacement
Was du brauchst
  1. Lenovo ThinkPad X280 Fan Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 3, Bild 2 von 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X280 Fan Assembly Replacement, Fan Assembly: Schritt 4, Bild 2 von 2
    • Using the Phillips #1 screwdriver, loosen the four captive screws attached to the heat sink until a small pop sound heard.
    • The screws do not come all the way out and remain partially attached to the heat sink.
  5. Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 5, Bild 2 von 2
    • Using the black spudger, gently push out the gray plastic connecter from the plug.
  6. Lenovo ThinkPad X280 Fan Assembly Replacement: Schritt 6, Bild 1 von 1
    • Loosen and remove the fan.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jordan Wooten
594 Reputation
4 Anleitungen geschrieben
University of Alabama, Team 1-3, Bedsole Fall 2021 Mitglied von University of Alabama, Team 1-3, Bedsole Fall 2021
UA-BEDSOLE-F21S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 90
Insgesamt: 2,220
