Zum Hauptinhalt wechseln
Lenovo ThinkPad X280 Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad X280 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • To begin, ensure that the device is powered off and not plugged into a energy supply.
    • Open the device to where you are directly viewing the screen with the keyboard laying flat.
  2. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Using the flat end of the spudger, insert it at the top of the right click button.
    • Pry it up to remove the button.
    • Repeat for the left click button.
  3. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the two 5 mm screws.
  4. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Using the black spudger tool, gently lift under the plastic where the screws were located.
    • Slide the keyboard towards the screen of the LenovoThinkPad X280 and lift the front edge by hand.
  5. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the keyboard from the device and flip it over.
    • It should still be attached with connectors on the far left corner at the top so be careful not to rip or pull the keyboard out.
  6. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the keyboard and trackpad cables locks with the pointed end of the black spudger.
  7. Lenovo ThinkPad X280 Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad X280 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Gently pull the cables from the rectangular connection site to detach the keyboard.
    • Remove the keyboard.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jordan Wooten
594 Reputation
4 Anleitungen geschrieben
University of Alabama, Team 1-3, Bedsole Fall 2021 Mitglied von University of Alabama, Team 1-3, Bedsole Fall 2021
UA-BEDSOLE-F21S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 133
Insgesamt: 3,397
