Zum Hauptinhalt wechseln
Lenovo ThinkPad X390 Fan Replacement
Was du brauchst
  1. Lenovo ThinkPad X390 Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and power down the laptop before proceeding with the guide.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Using a Phillips #0 screwdriver, unscrew the five screws on the base cover.
    • The screws are not removable.
  2. Lenovo ThinkPad X390 Fan Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X390 Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the base cover by inserting a plastic opening tool in between the cover and the rest of the laptop.
    • Once the tool is inserted, slide the tool along the edges of the case and push down on the opening tool to detach the case.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo ThinkPad X390 Fan Replacement, Fan: Schritt 3, Bild 1 von 1
    • Unplug the fan connector from the motherboard.
  4. Lenovo ThinkPad X390 Fan Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #0 screwdriver, unscrew the four screws holding the heat sink to the motherboard.
  5. Lenovo ThinkPad X390 Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift the fan up and out and remove it from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nick Couch
252 Reputation
1 Anleitung geschrieben
Clemson, Team 5-1, Hunter Fall 2021 Mitglied von Clemson, Team 5-1, Hunter Fall 2021
CLEM-HUNTER-F21S5G1
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 31
Insgesamt: 839
