Was du brauchst
Use a Phillips #0 screwdriver to remove the five 2.7 mm screws on the base cover.
Insert a plastic opening tool between the base cover and the chassis.
Slide the tool along the perimeter of the case and push down as you go to release the base cover.
Lift the base cover up and off.
Use tweezers to grip the battery's motherboard plug, and pull the plug directly out of its port.
Use a Phillips #0 screwdriver to remove the four 5.2 mm screws securing the battery.
Using your hands, remove the battery from the laptop.
Lift the battery up and out of its housing.
Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the SSD to the motherboard.
Ein Kommentar
I have been building computers for 15+ years, i didn't go to a fancy college but even I know this tutorial is for replacing the SSD or M.2 to be specific for a X390 laptop. this is not the ram module
