Zum Hauptinhalt wechseln
Lenovo ThinkPad X390 Yoga Display Replacement
Was du brauchst
  1. Lenovo ThinkPad X390 Yoga Display Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Use a Phillips #1 screwdriver to unscrew the eight captive screws from the back of the device.
    • The screws should not be removed from the back panel, so don't try to force them out.
  2. Lenovo ThinkPad X390 Yoga Display Replacement: Schritt 2, Bild 1 von 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
  3. Lenovo ThinkPad X390 Yoga Display Replacement: Schritt 3, Bild 1 von 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Display Replacement, Display: Schritt 4, Bild 1 von 2 Lenovo ThinkPad X390 Yoga Display Replacement, Display: Schritt 4, Bild 2 von 2
    • Disconnect the display connectors with a spudger or opening tool.
  5. Lenovo ThinkPad X390 Yoga Display Replacement: Schritt 5, Bild 1 von 1
    • Loosen the two 5.5mm screws using the Phillips #1 screwdriver.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 18
Letzte 30 Tage: 82
Insgesamt: 855
