Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement, LCD: Schritt 1, Bild 1 von 1
    • Start by putting on your anti static wrist strap and connecting it to a stationary and stable object, like a desk.
    • This safety strap serves as a precaution to prevent any electrical static you might have on your body from transferring to the laptop's internal components and damaging the hardware.
    • Reminder to have this safety strap on you at all times during the process
  2. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 2, Bild 2 von 2
    • Use a T5 screwdriver to remove the two 7.62 mm screws circled in red at the bottom of the front of the display.
  3. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 3, Bild 3 von 3
    • Heat up the iopener and apply it to all 4 edges of the display
    • Be cautious when handling the iopener as the contents are hot and follow the instructions written on the product.
    • You might need to heat up the iopener multiple times to melt the glue holding the dsoplay in place
  4. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 4, Bild 2 von 2
    • Use the Jimmy pick knife to pry the display open all around.
  5. Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 11e (Gen 5) LCD Replacement: Schritt 5, Bild 3 von 3
    • Finally, unplug the 2 connection points of the display from the motherboard.
    • The big port will have a silver latch that needs to be flipped up for the port to come out.
    • You can now replace the old display with the new one.
Abschluss
Onel
173 Reputation
1 Anleitung geschrieben
Gateway, Team 11-11, Gonzalez Spring 2024 Mitglied von Gateway, Team 11-11, Gonzalez Spring 2024
GCC-GONZALEZ-S24S11G11
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 27
