Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Screen: Schritt 1, Bild 1 von 2 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Screen: Schritt 1, Bild 2 von 2
    • Wearing the anti-static wrist strap will prevent a static shock from damaging the components in the laptop.
    • Disconnect the laptop from power and make sure it is completely powered off.
    • Turn the laptop facing down.
    • Loosen the eight captive screws using a JIS #0 screwdriver.
    • The screws are attached to the panel and cannot be removed.
    • Carefully remove the panel.
  2. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 2, Bild 3 von 3
    • Carefully disconnect the two sliding connectors in the left and right corner.
    • Disconnect the sliding connector on the Wi-Fi board.
    • Loosen the four 9.7 mm screws on the hinges in the top left and right corners using a Phillips #0 screwdriver.
    • Carefully lift the closest part of the laptop away from the screen side of the laptop.
  3. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 3, Bild 3 von 3
    • Using tweezers, gently pry and remove the covers on the LCD strip.
    • Remove the two 3.3 mm screws that were previously under the covers on the LCD strip using a Phillips #0 screwdriver.
    • Carefully lift and remove the LCD strip.
  4. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 4, Bild 1 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 4, Bild 2 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 3.3 mm screws from the silver panels using a Phillips #0 screwdriver.
    • Remove the two 3.3 mm screws from the LCD panel using a Phillips #0 screwdriver.
    • Carefully lift the screen towards you. You may use the spudger to assist lifting the screen. There will be one more connector on the side of the screen.
    • Carefully remove the ribbon connectors by gently pulling with your fingers.
  5. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement, Hinges: Schritt 5, Bild 3 von 3
    • Remove the four 3 mm screws that are closest to you using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws that are further from you using a Phillips #0 screwdriver.
  6. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 6, Bild 1 von 2 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 6, Bild 2 von 2
    • Grab the stopper and pull it out of the right hinge.
    • Remove the wire from the hinge.
  7. Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 7, Bild 1 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 7, Bild 2 von 3 Lenovo ThinkPad Yoga 11e Gen 6 Hinges Replacement: Schritt 7, Bild 3 von 3
    • Grab the stopper and pull it out of the left hinge.
Abschluss
Lex
509 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 101
