Einleitung
Is your computer getting too hot and randomly powering down? Try replacing your fan by following these steps.
Was du brauchst
Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
There is a wire looped around the fan. Use the spudger to pull the wires out of the loop.
