Einleitung
This guide explains how to safely remove the battery from your Lenovo Thinkpad Yoga 14 20FY.
Was du brauchst
Remove the indicated nine M2 x 6 mm nylon-coated screws using a Phillips head screwdriver.
After removing all of the screws, gently lift up on all covers to remove the back plate and reveal the interior of the device.
To remove the battery, use a Phillips head screwdriver to unscrew four screws. They are located at the four corners.
There will also be a clip that attaches the battery to the rest of the laptop. Unclasp the clip from its holding to completely free the battery.
Once all wires are detached from the rest of the computer, remove the battery from the laptop and replace.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
What size screwdriver do you need to remove the screws for the back cover?
Even the Hardware Maintenance Manual from Lenovo's website doesn't state the screwdriver size. I used a PH00 and it fit well.
Mike -
I did all the steps for removal, but I have a problem with the installation of the new battery. I can’t seem to manage to connect the wires (bundled into the plastic black thingy) back into the compartment from which I released the thingy that was connected to the old battery . In other words, I can’t do the opposite of Step 5 and push it back in. If anyone can post a picture or even a short video of how to insert it back, I would appreciate it. Right now my Laptop says there’s no battery, even though I connected it, so I must be doing something wrong. Thanks. G.
After connecting new battery, system showing as plugged in but the charging light is not glowing? If I replace old battery charging light comes fine! Any idea?
Suggestion: disconnect the CMOS (coin) battery while installing the battery, then plug it back in afterwards.
After installing the replacement battery sold by iFixit, I was presented with a message that the battery was not genuine and that it would not charge. I could still boot the computer, but the computer would not report the battery charge percentage. I tried flashing the BIOS to an updated version (v1.59), but that did not help. What helped in the end was disconnecting the CMOS battery and plugging it in again. While disconnected, I also pressed the small button labeled BTN1 (just below where the CMOS battery's wires plug into the main board in the photo for Step 4 above) for 5 seconds, in case that might reset something.
