Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Unplug and completely shut down your computer beforehand to reduce the risk of electric shock.
    • Flip the laptop over so you can see the bottom panel.
    • Unscrew the circled screws to detach the keyboard.
  2. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop back over and open it normally.
    • Use a plastic opening tool to lift up the keyboard along the bottom edge until it is detached.
  3. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Using a finger, push the top of the keyboard out of its holder to completely detach it.
    • Move the keyboard out of the way by rotating the far side of the keyboard towards you.
  4. Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Yoga 14 20FY Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Be gentle! These connectors are very small and can easily break off.
    • Lay the keyboard on its front.
    • Disconnect the 3 cables by pulling on the attached tabs.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S14-G2, Banghart Spring 2017 Mitglied von Cal Poly, Team S14-G2, Banghart Spring 2017
CPSU-BANGHART-S17S14G2
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 5,564
