Einleitung
If your battery is not functioning properly, this guide will highlight the steps on how to replace it.
Was du brauchst
Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
Using a plastic opening tool, gently pry the bottom cover from the laptop.
Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
Fold back the plastic cover to access the battery connection.
Remove the battery connection using your two index fingers.
Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
Lift the battery free from its mounting and remove it.
7 weitere Personen haben diese Anleitung absolviert.
