Einleitung
For the Lenovo ThinkPad Yoga 370 (Model Number: 20JH002AUS), if the battery is not charging the device, it could be faulty and this guide will show step by step instructions on how to replace the faulty battery.
Caution: When replacing the battery, make sure the replacement battery is the exact same type as before. Replacement of a wrong battery could cause it to ignite.
Was du brauchst
Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
With your fingers, fold back the plastic cover highlighted.
Using two fingers, gently remove the battery connectors.
Using the Phillips #00 screwdriver, remove the two 4mm screws.
Remove the battery.
Note: Due to the similarity of the devices, several of the pictures were used from the Lenovo ThinkPad Yoga 260 Battery Replacement Guide to show the specific components that were missing in the Yoga 370.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
There’s a procedure you must do before removing any of the screws- disable the battery!
