Einleitung
How to replace the keyboard in a Lenovo ThinkPad Yoga 2013. This guide will help you to successfully replace your keyboard.
Was du brauchst
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove two screws from the battery using a Phillips #1 screwdriver.
Disconnect the battery connector from the motherboard.
Remove the battery from the laptop.
Disconnect connectors. Use fingers to pinch and pull the connector out.
Remove the two screws from the retainer for the ports using a Phillips #1 screwdriver.
Remove the nine screws from the motherboard using a Phillips #1 screwdriver.
Remove the four screws from the fan under the motherboard using a Phillips #1 screwdriver.
Remove the fan from the motherboard.
Remove twelve screws from the midframe using a Phillips #1 screwdriver.
Use a spudger to pry open the keyboard panel.
Continue to pry until the panel is loose enough to take off.
2 weitere Personen haben diese Anleitung absolviert.
