Einleitung
This guide will help you replace a motherboard step by step. From beginning to end this guide will take you from beginner to expert in easy efficient fashion.
Was du brauchst
Using a plastic opening tool or opening pick, gently pry the screen off.
Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
Lift the screen up slowly.
Open the clips of the ZIF connectors and gently grab the cable to pull it out.
Remove the seven, 3mm, Phillips #00 screws attaching motherboard to the back cover.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
