Einleitung
This guide will show you how to replace your Optical/ DVD Drive if yours has become jammed or broken.
Guide Notes
- This installation is hardware only, and does not require any firmware installments.
- DVD drive may carry charge if laptop was recently active, use ESD bracelet to discharge any currents.
- Optical Lasers emit radiation, be careful NOT to break/open the drive casing.
Was du brauchst
While holding the latches, slide the DVD drive away from the compartment and remove it from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
