Zum Hauptinhalt wechseln
Lenovo Thinkpad T410i LCD Screen Replacement
Was du brauchst
  1. Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: Schritt 1, Bild 1 von 2 Lenovo Thinkpad T410i LCD Screen Replacement, Screen Bezel: Schritt 1, Bild 2 von 2
    • Use a spudger to remove the plastic covers from the LCD screen.
  2. Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
  3. Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to separate the bezel of the LCD screen.
  4. Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 4, Bild 1 von 3 Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 4, Bild 2 von 3 Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Continue along the edges lifting up and prying off the plastic LCD bezel.
  5. Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: Schritt 5, Bild 1 von 2 Lenovo Thinkpad T410i LCD Screen Replacement, LCD screen: Schritt 5, Bild 2 von 2
    • Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
  6. Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 6, Bild 1 von 3 Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 6, Bild 2 von 3 Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Place the LCD screen safely down on its front.
    • Pulling the screen too far away from the screen may damage delicate ribbon cable.
    • Peel the tape off the ribbon cable's contacts.
    • Carefully detach the ribbon cable from the LCD screen.
    • Poking the golden contacts may easily damage them.
  7. Lenovo Thinkpad T410i LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the screen from your device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Harsh Patel
287 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G2, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G2, Thompson Fall 2017
USFT-THOMPSON-F17S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 578
