Einleitung
If the LCD screen of your Lenovo ThinkPad T410i is broken or you wish to install a new screen, this guide will show you how to replace and reinstall the screen.
Guide notes
- This guide is hardware only, and it would not help resolve issues such as screen staying black or screen not responding to input.
- Unplug the system from the power source (if it is plugged in), and remove the battery before you perform any of the steps.
- Once you install the new LCD screen, safely dispose the old one.
Was du brauchst
Remove the two 6.0mm screws on each side using Philips #0 head screwdriver as shown in the picture.
Use a Philips #0 head screwdriver to remove the two 6.0mm screws from the top corners of the LCD screen.
Place the LCD screen safely down on its front.
Peel the tape off the ribbon cable's contacts.
Carefully detach the ribbon cable from the LCD screen.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
