Einleitung
Is your device turning off unexpectedly or not properly holding a charge? Consider using this guide to replace the battery in your device.
Was du brauchst
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
Use the Phillips #1 screwdriver to remove the three screws holding in the battery.
3 weitere Personen haben diese Anleitung absolviert.
