Einleitung
In order to access and replace the laptops components, the backplate must be removed. For this guide, you will need a prying tool and a Phillips #1 screwdriver. This process is not difficult but is required for most of this laptops repairs.
Was du brauchst
Make sure to power down and turn off your device before proceeding with the repair.
Flip your laptop over so that the backside is facing you.
Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
