Zum Hauptinhalt wechseln
Lenovo Thinkpad T440s Fan Replacement
Was du brauchst
  1. Lenovo Thinkpad T440s Fan Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo Thinkpad T440s Fan Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Make sure to power down and turn off your device before proceeding with the repair.
    • Flip your laptop over so that the backside is facing you.
    Frag FixBot
  2. Lenovo Thinkpad T440s Fan Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the eight screws securing the backplate.
    • Don’t try to force screws which won't come out. They are held in place by a stopper on the reverse side. This will not prevent you from removing the backplate.
    Frag FixBot
  3. Lenovo Thinkpad T440s Fan Replacement: Schritt 3, Bild 1 von 2 Lenovo Thinkpad T440s Fan Replacement: Schritt 3, Bild 2 von 2
    • Using the metal spudger, wedge it in the seam where the backplate meets the front plate and run the tool along the seam to separate the backplate.
    Frag FixBot
  4. Lenovo Thinkpad T440s Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the back panel from the device.
    Frag FixBot
  5. Lenovo Thinkpad T440s Fan Replacement, Fan: Schritt 5, Bild 1 von 2 Lenovo Thinkpad T440s Fan Replacement, Fan: Schritt 5, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the four screws holding in the fan assembly.
    Frag FixBot
  6. Lenovo Thinkpad T440s Fan Replacement: Schritt 6, Bild 1 von 3 Lenovo Thinkpad T440s Fan Replacement: Schritt 6, Bild 2 von 3 Lenovo Thinkpad T440s Fan Replacement: Schritt 6, Bild 3 von 3
    • Lift the fan out of it's compartment to gain access to the cable connection, firmly grab the cable and pull it out of it's housing.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 Mitglieder
11 Anleitungen geschrieben
5 Kommentare zur Anleitung
It would be helpful to have something about the fan too!
Where to get it, or at least the model number!
Iraj V - Antwort Teilen
What about thermal grease?
Oscar Desmonteix - Antwort Teilen
Useless info. This is the heatsink (with fan) replacement, NOT fan replacement. The poster is a moron.
Victor Song - Antwort Teilen
Victor - The fan and heatsink are attached to one another. How would you propose one replace the fan only? If you have a method, please create your own guide if this one was authored by such a “moron”. Jeez.
tomwedell - Antwort Teilen
Is there a way to tell if your fan is bad before ordering a replacement and opening my t440s?
Beckco - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 32
Letzte 30 Tage: 104
Insgesamt: 7,385
