Zum Hauptinhalt wechseln
Lenovo Thinkpad T440s Keyboard Replacement
Was du brauchst
  1. Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Lenovo Thinkpad T440s Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Start with the laptop open and the keyboard exposed.
  2. Lenovo Thinkpad T440s Keyboard Replacement: Schritt 2, Bild 1 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 2, Bild 2 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Use the metal spudger to press the keyboard plate forward towards the display
  3. Lenovo Thinkpad T440s Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdrivers to remove the six screws holding in the keyboard.
  4. Lenovo Thinkpad T440s Keyboard Replacement: Schritt 4, Bild 1 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 4, Bild 2 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use the metal spudger to lift up the keyboard plate.
    • Run the metal spudger around the plate, applying light pressure until the keyboard pops out.
  5. Lenovo Thinkpad T440s Keyboard Replacement: Schritt 5, Bild 1 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 5, Bild 2 von 3 Lenovo Thinkpad T440s Keyboard Replacement: Schritt 5, Bild 3 von 3
    • The keyboard can now be rested forward to expose the ribbon cable attaching it to the motherboard.
    • The ribbon cable will come out with a light pull in the opposite direction of its connection.
    • The keyboard is now removed and ready to be replaced.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Terelle Montalvo
1.477 Reputation
8 Anleitungen geschrieben
UMass Dartmouth, Team S1-G5, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G5, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G5
3 Mitglieder
Ein Kommentar
how can i get a video for guideline?
Taiye Phisical - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 32
Letzte 30 Tage: 59
Insgesamt: 5,904
