Einleitung
Are some of your keys not working when you type? Consider using this guide to replace the keyboard of your device.
Was du brauchst
Use a Phillips #00 screwdrivers to remove the six screws holding in the keyboard.
Use the metal spudger to lift up the keyboard plate.
Run the metal spudger around the plate, applying light pressure until the keyboard pops out.
The keyboard can now be rested forward to expose the ribbon cable attaching it to the motherboard.
The ribbon cable will come out with a light pull in the opposite direction of its connection.
The keyboard is now removed and ready to be replaced.
5 weitere Personen haben diese Anleitung absolviert.
