Einleitung
This guide is used for the replacement of the fan assembly in the Lenovo Thinkpad T450s. Ample lighting and storage for small parts recommended.
Was du brauchst
Flip the laptop over so that the bottom is facing up.
Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
Lift off the back cover.
Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
Remove the fan and heat sink assembly from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
