Zum Hauptinhalt wechseln
Lenovo Thinkpad T450s Keyboard Replacement
Was du brauchst
  1. Lenovo Thinkpad T450s Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo Thinkpad T450s Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 5mm screws on the back cover using the Phillips #0 screwdriver.
  3. Lenovo Thinkpad T450s Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Keyboard Replacement: Schritt 4, Bild 1 von 2 Lenovo Thinkpad T450s Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Flip the laptop, shift the keyboard upwards by applying force to the two indents on the keyboard.
    • Remove the six 5mm screws that are on the keyboard using the Phillips #0 screwdriver.
    • These screws are located above the left ctrl key, S, F, J, semicolon, and up arrow keys.
  5. Lenovo Thinkpad T450s Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the keyboard and flip over exposing the connection to the motherboard.
  6. Lenovo Thinkpad T450s Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic covering and detach touch point and keyboard cable.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Morgan
469 Reputation
2 Anleitungen geschrieben
IUPUI, Team S2-G5, Stella Fall 2019 Mitglied von IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Mitglieder
Ein Kommentar
If after replacement your keyboard has some keys clacking, make sure you slid the keyboard all the way back. Even a small amount can make some keys feel weird.
Ivan Veloz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 108
Insgesamt: 5,877
