Zum Hauptinhalt wechseln
Lenovo Thinkpad T450s Motherboard Replacement
Was du brauchst
  1. Lenovo Thinkpad T450s Motherboard Replacement, Fan: Schritt 1, Bild 1 von 1
    • Flip the laptop over so that the bottom is facing up.
    • Unlock the battery by sliding the keys outwards. When unlocked, push the battery forwards to remove.
  2. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all 3.7 mm Phillips #0 screws from the back of the laptop. Half of them will remain attached to the cover.
    • Lift off the back cover.
  3. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the four 5 mm Phillips #0 screws that secure the heatsink.
    • The screws will remain attached.
    • The Fan is attached to the heat sink assembly.
  4. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool or a nylon spudger to push the fan's bundled cable connector free.
    • Remove the fan and heat sink assembly from the motherboard.
  5. Lenovo Thinkpad T450s Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove all twelve 3.6 mm Phillips #00 screws.
  6. Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: Schritt 6, Bild 1 von 2 Lenovo Thinkpad T450s Motherboard Replacement, Remove the Hard Drive: Schritt 6, Bild 2 von 2
    • Remove the hard drive from the motherboard's by gently pulling it out and up at the same time.
  7. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull out the socket that is attached to the left side of the battery case.
  8. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Unplug the cable that attaches the polymer battery to the motherboard by pulling it out carefully.
  9. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the ribbon cable attached to the the battery case carefully by pulling the cable up and out.
  10. Lenovo Thinkpad T450s Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the motherboard from the case. If the motherboard does not come off the case or feels stuck, make sure that you have removed all the cables prior
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team 2-3, Harley Spring 2022 Mitglied von IUPUI, Team 2-3, Harley Spring 2022
IUPUI-HARLEY-S22S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 46
Insgesamt: 1,271
