Einleitung
If you are having display issues, you may find that you need to replace the screen. You can utilizes this guide to give you step by step instructions on how to replace the screen on your device.
Was du brauchst
Pry the bottom right corner of the screen’s border and gently peel off the adhesive screen cover
Slowly lean the computer forward so that the screen gently falls into your hand
6 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
there is a step where you remove a simple harness which requires a spudger to de-clip it from the main frame of the laptop, but I gotta say that this walkthrough REALLY was the big difference maker for me in feeling like I could do this job. THANK YOU!!!!!
Correct you are... it important to point that because you can damage it with too much presure trying to get the screen out. Cause I was like, hold up! My screen didnt just flop out like his after removing the four screws that held the screen in place. Luckily, while applying lite pressure trying to get the screen out, the plastic frame popped apart, and I was like okay! Ole boy didnt mention this. So yeah. Please remove that plastic frame before you remove the screen.
Uno!
