Zum Hauptinhalt wechseln
Lenovo Thinkpad T450s Trackpad Replacement
Was du brauchst
  1. Lenovo Thinkpad T450s Trackpad Replacement, Trackpad: Schritt 1, Bild 1 von 1
    • Remove the battery by pulling on the two sliding buttons next to the battery.
  2. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back cover and remove the back cover.
  3. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 3, Bild 1 von 2 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 3, Bild 2 von 2
    • Remove the two rubber stoppers from where the battery previously was.
  4. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 4, Bild 1 von 3 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 4, Bild 2 von 3 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the three 5mm screws around the battery.
    • Unplug and remove the battery.
  5. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 5, Bild 1 von 3 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 5, Bild 2 von 3 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 5, Bild 3 von 3
    • Remove the ten 5mm screws holding down the motherboard using the Phillips #0 screwdriver.
  6. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 6, Bild 1 von 1
    • Remove the flat flex cable that connects the touchpad to the laptop.
  7. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 7, Bild 1 von 2 Lenovo Thinkpad T450s Trackpad Replacement: Schritt 7, Bild 2 von 2
    • Use the Phillips #0 screwdriver to remove the single screw holding the hard drive.
    • Remove the hard drive from the device.
  8. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 8, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the two 5mm screws that connects the toughpad to the computer.
  9. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 9, Bild 1 von 1
    • Remove the cable in the left hand of this picture that connects the motherboard to hard drive.
  10. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 10, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the the two 5mm screws in this image and then remove the glue flex cable being held.
  11. Lenovo Thinkpad T450s Trackpad Replacement: Schritt 11, Bild 1 von 1
    • Flip the laptop and remove the touchpad, it will pop right out.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Morgan
469 Reputation
2 Anleitungen geschrieben
IUPUI, Team S2-G5, Stella Fall 2019 Mitglied von IUPUI, Team S2-G5, Stella Fall 2019
IUPUI-STELLA-F19S2G5
3 Mitglieder
4 Kommentare
Hello,
I would like to ask you one thing - do you recall if the TouchPad can be adjusted (position wise) before srewing down? I have this problem where the right side on the TouchPad is too close to the palmrest (between spacebar and the TrackPoint buttons), and when I click the right physical button it collides with it, providing not so great using experience. So I was wondering it is posiible to losen the screws and move it back a little.
Is it possible? Thanks in advance for answear.
Adrian Wiechnik - Antwort
Do I have to reinstall drivers after this? I replaced the touchpad but now two fingers scrolling is not working. Any ideas?
Manuel Amaro - Antwort
Do I have to remove the keyboard to replace the touchpad for thinkpad t450?
It does not seem necessary when following the instructions above!
TheTruthWillSetYouFree - Antwort
Will post here again to warn people. Be very careful when removing the flat flex glue cable that attaches to the motherboard. The clamp can easily be damaged by just manipulating the cable. Make sure to open the clamp first before removing or the clamp may break and will not be able to be replaced other than replacing the main board!
PC Fixer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 32
Insgesamt: 4,964
