Zum Hauptinhalt wechseln
Lenovo Thinkpad Twist s230u Battery Replacement
Was du brauchst
  1. Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: Schritt 1, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement, Hard Drive: Schritt 1, Bild 2 von 2
    • Flip the laptop over.
    • Using a Phillips #1 Screwdriver, unscrew the screw on the bottom left corner.
  2. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 2, Bild 1 von 1
    • Using the iFixit Opening tool, loosen the hard drive cover.
  3. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the hard drive cover.
  4. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the hard drive by sliding it out.
  5. Lenovo Thinkpad Twist s230u Battery Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  6. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  7. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  8. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 8, Bild 1 von 3 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 8, Bild 2 von 3 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 8, Bild 3 von 3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
  9. Lenovo Thinkpad Twist s230u Battery Replacement, Upper Casing: Schritt 9, Bild 1 von 1
    • Flip your device over.
    • Use the Phillips #1 screwdriver to remove the nine screws.
  10. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 10, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 10, Bild 2 von 2
    • Flip the device back over and open the top.
    • Use the Phillips #1 screwdriver to remove the seven silver screws.
    • Disconnect the three cables inside the case.
    • Lift up the brown tab and disconnect the ribbon cable.
  11. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 11, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 11, Bild 2 von 2
    • Close the lid and turn the device around.
    • Use the iFixit Opening Tool to lift up and remove the tab on the back.
  12. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 12, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 12, Bild 2 von 2
    • Turn the device back around and reopen it.
    • Use the iFixit Opening Tool to disconnect the top of the case from the bottom.
    • Lift up the top of the case and slide it out from under the screen.
  13. Lenovo Thinkpad Twist s230u Battery Replacement, Battery: Schritt 13, Bild 1 von 2 Lenovo Thinkpad Twist s230u Battery Replacement, Battery: Schritt 13, Bild 2 von 2
    • Remove the single silver screw using the Phillips #1 screwdriver.
  14. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 14, Bild 1 von 1
    • Unplug the colored cables.
  15. Lenovo Thinkpad Twist s230u Battery Replacement: Schritt 15, Bild 1 von 1
    • Lift the battery out of the laptop.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 64
Insgesamt: 4,160
