Zum Hauptinhalt wechseln
Lenovo Thinkpad Twist s230u Keyboard Replacement
Was du brauchst
  1. Lenovo Thinkpad Twist s230u Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Use a Philips #1 screwdriver to remove 2 screws on the bottom of the laptop.
  2. Lenovo Thinkpad Twist s230u Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to loosen the keyboard around the edges.
    • Carefully push the keyboard towards the screen to unlatch it.
    • Do not push too hard, as there are ribbon cables attached to the keyboard.
  3. Lenovo Thinkpad Twist s230u Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift up the keyboard to access the wires underneath.
    • Be careful not to break the ribbon cables attached underneath.
  4. Lenovo Thinkpad Twist s230u Keyboard Replacement: Schritt 4, Bild 1 von 3 Lenovo Thinkpad Twist s230u Keyboard Replacement: Schritt 4, Bild 2 von 3 Lenovo Thinkpad Twist s230u Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Open the small black flap on each of the ribbon cables. It should lift with a slight effort.
    • Pull out the ribbon cables and remove the keyboard from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 1,113
