Einleitung
If your Lenovo Thinkpad X1 Carbon 4th Generation is giving a blue screen, restarting randomly, has a burning smell coming from the motherboard use this guide to replace the motherboard (also known as a Logic board).
The motherboard is the main part of the computer and if it fails may cause other parts to fail.
Before using this guide, inspect the ribbon cable connections for everything attached to the motherboard.
Before beginning, make sure to power off your computer completely and disconnect from any external power source.
Was du brauchst
Unscrew the nine captive screws on the bottom cover of the laptop using a Phillips #1 screwdriver.
There are a few small clips around the edge that you may need to pry at to free them. An opening pick may be helpful for this process.
Carefully lift the far end of the battery connector with an opening tool facing towards you.
Remove the connector by pushing it forward and lifting.
Peel back the plastic protective cover above the main battery section to expose the coin-cell's red and black wires.
Gently unplug the coin-cell wires from the connector by pulling horizontally away from the connector.
Lift the coin cell out from the computer.
Unweave the blue and white wires from underneath the plastic tabs connected to the battery.
Carefully disconnect the gray and black antenna connectors on the green wireless LAN card by lifting under the antennas with an opening tool.
Remove the 2.5 mm screw holding the card in place with a Phillips #1 screwdriver.
Disconnect the antenna wires on green the wireless LAN card to the left of the fan.
Lift up the hinge connector that is attached to the fan's ribbon cable.
Carefully disconnect the cable by pulling outwards from the ribbon connector.
Using a Phillips #0 screwdriver, remove the two 5 mm screws securing the USB ports on the righthand side of the motherboard.
Using a Phillips #0 screwdriver, remove the five 5mm screws.
Using a Phillips #0 screwdriver, remove the four 2mm screws.
Remove the 7 ribbon cables connecting the motherboard to their respective components by flipping up the locking black tabs with a spudger and pulling the cables from their connectors.
Remove the red and blue wires attached to the motherboard.
Using the plastic opening tool, gently lift up on the motherboard.
Lift the motherboard out from the computer.
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
good work, thank you
Step 9 (speakers) needs to be done before you can do Step 5 (main battery) as the battery is attached by tabs under the speaker screws. If you don't do this then you'll break off those battery tabs like I did!
