Einleitung
Use this guide to remove the RAM (random access memory) from your device.
Was du brauchst
Remove the battery by sliding forward the switch here.
For more info on how to remove the battery, refer to battery replacement guide.
The RAM is the small square component on the back. Unscrew all screws using a diamond head screw.
There are only two screws to remove as circled here.
The screw head used here is a JIS J00 Driver.
On the edges of the RAM components, push each switch to the side.
The RAM chip should pop up on its own once you push each side outwards.
The RAM chip should pop up on its own once the sides are pushed outwards.
Gently pull on the RAM to remove.
2 weitere Personen haben diese Anleitung absolviert.
