Zum Hauptinhalt wechseln
Lenovo Thinkpad X240 RAM Replacement
Was du brauchst
  1. Lenovo Thinkpad X240 RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Flip the laptop up side down as shown in the photo.
  2. Lenovo Thinkpad X240 RAM Replacement: Schritt 2, Bild 1 von 2 Lenovo Thinkpad X240 RAM Replacement: Schritt 2, Bild 2 von 2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo Thinkpad X240 RAM Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo Thinkpad X240 RAM Replacement: Schritt 4, Bild 1 von 2 Lenovo Thinkpad X240 RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the RAM stick by carefully popping its holders out of place.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Does this Thinkpad really have only one RAM slot? Or is there another one on the back of the board (i.e. under the keyboard)?
Sebastian Swirski - Antwort
Would I be able to add a 16gb ram stick in it? Even though the highest spec config that the laptop ships with is only 8gb?
Mahir Max - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 4,634
