Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Werkzeuge
Keine Werkzeuge angegeben.
  1. Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
  2. Flip the computer upside down.
    • Flip the computer upside down.
    • The red rectangle shows the location of the battery.
  3. Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position. Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
    • Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
  4. Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer. Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer. Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
    • Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 weitere Nutzer haben diese Anleitung absolviert.
Johannes
875 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 22
Letzten 30 Tage: 74
Insgesamt: 3,611
