Einleitung
Users will learn how to remove the bezel from a Lenovo Thinkpad x230.
Was du brauchst
Flip the computer upside down.
The red rectangle shows the location of the battery.
Locate the two switches that lock the battery. Push the left-hand switch outward into the "unlocked" position.
Now push and hold the right clip to the right while using your other hand to gently slide the battery away from the computer.
Remove the screws (0.4, 0.5 cm) from the bottom corners of the bezel using a Phillips #0 screwdriver.
8 weitere Personen haben diese Anleitung absolviert.
