Zum Hauptinhalt wechseln
Lenovo Thinkpad x240 Internal Battery Replacement
Was du brauchst
  1. Lenovo Thinkpad x240 Internal Battery  Replacement, Internal Battery: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Device's lights should all be off.
  2. Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 2, Bild 1 von 2 Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 2, Bild 2 von 2
    • Remove the back cover by unscrewing the 8 0.2 mm screws holding it in place.
  3. Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 3, Bild 1 von 2 Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 3, Bild 2 von 2
    • Locate the internal battery pack and unscrew the 3 0.2 mm screws holding it in place.
  4. Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 4, Bild 1 von 2 Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 4, Bild 2 von 2
    • Unplug the connector cable that connects the internal battery pack to the laptop.
  5. Lenovo Thinkpad x240 Internal Battery  Replacement: Schritt 5, Bild 1 von 1
    • Insert the new internal battery pack into the laptop.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
“0.2 mm screws”? There is no such thing as 0.2mm screws! I can only assume that you’ve meant to write M2 screws though since you messed that up I’m wondering if it’s really M2 screws or if it could be M2.5 or even M3 screws instead.
This is crucial information to all those people who only have a battery dummy in their original configuration needing to figure out what screws to buy to secure the new actual internal battery inside the case.
eiion - Antwort
Two supply the missing information: According to the Maintenance Manual they are three M2x4mm.
eiion - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 34
Letzte 30 Tage: 96
Insgesamt: 15,699
