Einleitung
Having issues with your battery life? No worries! Follow this simple guide to replace the internal battery.
Was du brauchst
Locate the internal battery pack and unscrew the 3 0.2 mm screws holding it in place.
Unplug the connector cable that connects the internal battery pack to the laptop.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
“0.2 mm screws”? There is no such thing as 0.2mm screws! I can only assume that you’ve meant to write M2 screws though since you messed that up I’m wondering if it’s really M2 screws or if it could be M2.5 or even M3 screws instead.
This is crucial information to all those people who only have a battery dummy in their original configuration needing to figure out what screws to buy to secure the new actual internal battery inside the case.
