Einleitung
This guide will solve issues involving a defective battery, such as: Unexpected Shutdown, Laptop not Charging, Laptop Shuts down when Unplugged.
Was du brauchst
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the blue Opening Tool to pry-open the back cover.
Slide it around the perimeter of the PC freeing the back cover.
Remove the back cover from the device.
Use the Phillips #0 screwdriver to unscrew the three screws holding the battery.
To reassemble your device, follow the instructions on Step 3.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
