Einleitung
This guide will help you replace the hard drive of your device. You'll need to spend some time unscrewing a numerous amount of schools from the device.
Was du brauchst
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the blue Opening Tool to pry-open the back cover.
Slide it around the perimeter of the PC freeing the back cover.
Remove the back cover from the device.
Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
Remove the hard drive from the frame.
