Zum Hauptinhalt wechseln
Lenovo Touch Y70-70 Hard Drive Replacement
Was du brauchst
  1. Lenovo Touch Y70-70 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Use the Phillips #0 screwdriver to unscrew the four screws.
  4. Lenovo Touch Y70-70 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the hard drive from the motherboard.
  5. Lenovo Touch Y70-70 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Use the Phillips #0 screwdriver to unscrew the four screws on the sides of the hard drive frame.
    • Remove the hard drive from the frame.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 35
Insgesamt: 2,741
