Zum Hauptinhalt wechseln
Lenovo Touch Y70-70 Motherboard Replacement
Was du brauchst
  1. Lenovo Touch Y70-70 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Flip the device so that the back cover is facing you.
    • Using the Phillips #0 screwdriver, remove 14 screws from the back of the device.
  2. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 2, Bild 1 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 2, Bild 2 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the three screws holding down the battery.
  3. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 3, Bild 1 von 2 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the metal reinforcement by removing the three screws.
  4. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 4, Bild 1 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 4, Bild 2 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using the Phillips #0 screwdriver, carefully remove the three screws holding down the fan.
    • Detach the cables connecting the fan to the motherboard.
  5. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 5, Bild 1 von 2 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Using the Phillips #0 screwdriver, remove the six screws holding down the cooling unit.
  6. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 6, Bild 1 von 2 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the Ethernet port by unscrewing the two screws holding it down.
  7. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 7, Bild 1 von 2 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Unplug the various cables attached to the motherboard using your fingers carefully.
    • Detach the cables using your fingers.
  8. Lenovo Touch Y70-70 Motherboard Replacement: Schritt 8, Bild 1 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 8, Bild 2 von 3 Lenovo Touch Y70-70 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Finally, remove the six screws holding down the motherboard.
    • Remove the motherboard from the laptop.
Abschluss
IUPUI, Team S2-G5, Harley Fall 2019 Mitglied von IUPUI, Team S2-G5, Harley Fall 2019
IUPUI-HARLEY-F19S2G5
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 1,133
