Zum Hauptinhalt wechseln
Lenovo Touch Y70-70 RAM Replacement
Was du brauchst
  1. Lenovo Touch Y70-70 RAM Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device so the back is facing you.
    • Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
  2. Lenovo Touch Y70-70 RAM Replacement: Schritt 2, Bild 1 von 1
    • Use the blue Opening Tool to pry-open the back cover.
    • Slide it around the perimeter of the PC freeing the back cover.
    • Remove the back cover from the device.
  3. Lenovo Touch Y70-70 RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Lenovo Touch Y70-70 RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Use your fingers or two of the blue Opening Tools to lightly pull the tabs away from the RAM to free the first stick.
    • Remove the first stick and and do the same thing to the second RAM stick.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 274
