Zum Hauptinhalt wechseln
Lenovo V14-ADA Screen Replacement
Was du brauchst
  1. Lenovo V14-ADA Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Screen Replacement: Schritt 3, Bild 1 von 2 Lenovo V14-ADA Screen Replacement: Schritt 3, Bild 2 von 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Screen Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo V14-ADA Screen Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
  5. Lenovo V14-ADA Screen Replacement, Screen: Schritt 5, Bild 1 von 3 Lenovo V14-ADA Screen Replacement, Screen: Schritt 5, Bild 2 von 3 Lenovo V14-ADA Screen Replacement, Screen: Schritt 5, Bild 3 von 3
    • Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
    • Use the Jimmy to pop the surrounding screen bezel off.
  6. Lenovo V14-ADA Screen Replacement: Schritt 6, Bild 1 von 2 Lenovo V14-ADA Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 3 mm screws at the top two corners of the screen using a JIS #0 screwdriver.
  7. Lenovo V14-ADA Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the screen from the laptop.
Abschluss
Samaya Roukoz
253 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 Mitglied von UMass Dartmouth, Team 4-2, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G2
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 172
