Einleitung
This guide will show how to access, disconnect, and remove the hard-disk drive from your Lenovo V15-ADA device.
Was du brauchst
Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
M2.5 × 7 mm, Phillips-head (6) (RED circles)
M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
Repeat for all 4 sides until loose.
Pop off the back plate and set aside.
To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
M2 × 6 mm, Phillips-head, nylok-coated (3)
Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
Eine weitere Person hat diese Anleitung absolviert.
