Zum Hauptinhalt wechseln
Lenovo V15-ADA Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 2 Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: Schritt 1, Bild 2 von 2
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 2, Bild 1 von 2 Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 2, Bild 2 von 2
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 1
    • Remove the Black wire with your fingers or small ESD-safe tweezers.
  4. Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove Grey wire.
  5. Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Unscrew screw holding Wi-Fi card in place.
    • 1x M2 x 3mm, Phillips #1.
  6. Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Card will lift up after screw is out of place.
  7. Lenovo V15-ADA Wi-Fi Card Replacement: Schritt 7, Bild 1 von 1
    • Pull Wi-Fi card out of slot.
Abschluss
Jacob Schorr
442 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 43
Insgesamt: 206
