Einleitung
If your phone is having issues holding a charge or the battery doesn't charge, it might be time to replace your phone's battery. Find out how to replace it in this guide
Was du brauchst
Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
Push the Spudger along the gap between the phone and the backplate to separate them.
Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
Insert a fingernail or spudger into either side of the battery and lift upward.
Remove the battery from phone.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Where to buy such battery?
wala pa po ba dito s pinas ng bl230?
