Zum Hauptinhalt wechseln
Lenovo Vibe Z2 Pro Battery Replacement
Was du brauchst
  1. Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: Schritt 1, Bild 1 von 2 Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: Schritt 1, Bild 2 von 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo Vibe Z2 Pro Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo Vibe Z2 Pro Battery Replacement: Schritt 4, Bild 2 von 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Lenovo Vibe Z2 Pro Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 7, Bild 1 von 2 Lenovo Vibe Z2 Pro Battery Replacement: Schritt 7, Bild 2 von 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Battery Replacement: Schritt 9, Bild 1 von 3 Lenovo Vibe Z2 Pro Battery Replacement: Schritt 9, Bild 2 von 3 Lenovo Vibe Z2 Pro Battery Replacement: Schritt 9, Bild 3 von 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 18-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Where to buy such battery?
Damir Dominko - Antwort
wala pa po ba dito s pinas ng bl230?
eduardo santos - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 3,352
